VPEX.AutoConfig.End
Description
VPEX Auto-Configuration without MLAG support has ended.
Remedy
Reasons for VPEX Auto-Configuration in non-MLAG mode being ended could be that CLI command 'disable vpex auto-configuration' was executed, or connection to MLAG peer was detected. VPEX Auto-Configuration can be re-enabled, but if it is enabled in MLAG mode, existing extended slot configuration will not be synced to the MLAG peer. User intervention might be needed. Further details may be seen via CLI scommands: "show vpex," "show mlag port," and "show vpex auto-configuration."
Severity
Notice
Message Text
VPEX Auto-Configuration in non-MLAG mode has ended.
